Hi, I'm new to this site and to getting a z. I have a 90z right now that I'm doing the turbo swap on and I've run into a bit of a problem. I went to start the motor to check and make sure it was gonna run and it cranked over fine but wouldn't fire off, so I checked the plugs and they were shot so I went and got new plugs. I go to crank it over today and the starter just clicks. Well to bypass that I just jumped the 2 posts on the started just to see if I could get it to pop off. Well that's when it quit cranking. So I pulled a plug and sure enough it was full of gas along with gas in the oil. Oh and there was gas pouring out of the exhaust side of the turbo when I was still able to crank it. Anybody out there that can give me some suggestions? Would be much appreciated. Thanks.
Nick
cylinders full of gas and gas in the oil - AcesZ19:12:51 04/08/11
